90 dr 350 kickstarter
Kick start shaft spring might be broken. This returns the kickstart to normal position. I would crack the clutch cover and check the spring before riding, a loose piece could tear things up.
Had this happen on my '90 too - opened it up and the oil pump driven gear had all 35 teeth shredded off and floating around the case. I wouldn't mess with the chance of that spring shearing off in your engine...
Good luck
