1993 xr250l wiring help
I have a 93 xr250l and im trying to eliminate the battery and wiring. Trying to make it run like a dirt bike. Any homemade wiring diagrams or help would be greatly appreciated. Thanks in advance
I don't know why you would want to do that.  Dirt bikes have a stator with a separate winding for the ignition.  The 250L has a street bike electrical system with a powerful three phase stator.  The CDI unit operates on DC.
You can replace the battery with a capacitor, but why?
The three yellow wires from the stator go to the regulator/rectifier.  From the Reg/rec. the green wire ties into all the other green wires and goes to ground, the red/white wire feeds 12volts DC to charge the battery. The small black wire from the reg/rec is not needed.  After that, everything runs off the battery.
