KYB crf 450 '09 damper road seal and bushing removal
Hello guys, can you help to replace this parts? tore down the seal and bushing assy yet from the cartrige, but it doesn't look like to split again like the old SSS KYB fork in two part to get inside...any tips?
In the first pic the seal head is complete, u need to hold just above the threaded part and use the hex tool to undo it .
Yep, this is what I nave tried to do! Heated up 'til the water droppets sizzle and tried to take it apart with the hex tool but it didn't move whatsever. What do you suggest?
How r u holding it, u may be clamping on the thread inside, I have some blocks for the 48mm Showa fork a and they only 12mm deep. So as not to be holding on the threaded section
How many ft/lbs to get it back together ? I'm doin my 09kx450
I got it this morning, but it is damaged, some threads melted in some spots, luckily I was able to fix it up a bit with a file, hope it can hold the torque when I put it back together!
what about the mod Davej suggested on this link, have you give it a try?
http://www.thumpertalk.com/topic/611060-fork-seal-head-mod-06-08yz-09-crf450r-07-09-kx450f/
as of the torque specs, later I'll post it up.
Edited by creed75
I am going to try this mod , just waiting on my parts from suspensiondirect. You would think $16 in shipping on a dozen shims and 2 seals would take less than a week
yeah, I can imagine your impatient!...I have not some reference about shipping fees and time in US, what's important is the result after the waiting! Let me know how the fork will work with the O-ring!
Don't see a need to put a o ring in
I didn't got the chance to give it a shot. The idea is good, because there is a problem with oil that go inside the cartridge when pressure builds up, I have some dubt about the result with the o-ring, but I do not have enough threads to put the o-ring.
To some degree they are designed to circulate the oil
Good point, but what about the imbalance in one side of the cc when this happen, how would the circuit system offset it?
They blow off the excess oil like when you do a final bleed
Edited by mog
the point is at high rod rod velocity the bouncing up of pressure cause oil sweeping inside of the cartridge rebound chamber and there is an imbalance with the comp chamber, the idea behind the o-ring is to avoid that.
Edited by creed75
yep, you right, but the oil is into the rebound chamber at first and before the excess oil transits to the comp one you don't think it might give rise some cavitation? Edited by creed75
I think excess pressure will stop cavitation but might cause harshness
It won't creat harshness, the inner cart can never be overfilled for to long because it will blow off once bottomed. I've stripped forks down where 1 is empty and one normall, customer is suprised the cartridge needs a repair, and seen wp forks with over 2.5bar in them.
Some people never bottom and so they stay pumped up
