06 kx450f starts then after about 10 min dies
So i own a 06 kx450f and recently it has started to die after about 10 min of run time it doesn't matter if i run it hard or just  let it idle also ive noted that it is running hotter at the pipe witch is also new. I have taken it a part and cleaned the carb just with carb cleaner, never took the carb apart witch Im scared to do cause i don't know if i have the skill that it takes to put it all together and have it run right.
Explain what you mean by "die"? eg. just gradually shuts down, or gets rough then dies?
Try clearing or unplugging the fuel cap vent hose valve.
Do you lose any coolant?  If yes or maybe, then after it dies, pull out the spark plug and smell for any coolant. Maybe your head gasket is leaking.
