Won't run
My 2006 rmz 250f won't run it's firing the timing is spot on the valves are shimmed I have been thru the carb 4 times and about 200 kicks it won't run I have even tried roll starting it and nothing I have raplaced the entire inviting system the cdi the coil the stator and nothing I just don't know can any body help me
Confirm that it has timing, spark,fuel,compression. If it has those 4 things-it has to fire. If I had to guess it would be spark. Did you ground the plug and see if it arcs across? Wet the plug and see if it fires. This will confirm if its not getting fuel. If it has spark and all the other items are good a really hard to troubleshoot across a computer. Best of luck. Hole you get it running
