The grinding sounds of metal
Hi,
Can not get over the grinding sound of metal from within the front fork after installing Eibach springs in my 2009 CRF450X
The Eiabch springs are shorter and they come with shims to compensate the length, they are also 1mm smaller in diameter. I have tried the correct amount of shims, bellow and above the correct amount but with no success... The noise is of rubbing metal parts and comes from the area above the oil seals. The noise miraculously disappears after putting the OEM springs back in.
Any ideas?
Thanks
Edited by Oran
1 mm smaller sounds too much
