2011 KTM350sxf crashed in swamp now will not start
Changed oil ,filter, cleaned screen, pulled air cleaner and cleaned, replaced gas, also replaced TPS, bike turns over very good, has great spark, fuel inj. is spraying fuel, but the spark plug is dry...... Is it possible that the bike jumped time? And if so how? And how do I check?  all connections have been cleaned and reassembled with elc grease. Was running great untill I went down in the water.
When you replaced the tps did you readjust it to .640V ?
It must be adjusted properly or the bike will no run.
Search you tube for videos on adjusting it.
well thats a strong clue,  what ever generates the voltage maybe suspect
