Clutch Rebuild Problems
I just completely rebuilt my 2009 crf250r clutch, new basket, springs, and plates. It no longer disengages when you pull the clutch. There is pressure on the lever but pulling it does nothing. I don't know what went wrong but any suggestions would be helpful.
Cable adjusted properly? Did you visually check with the clutch cover off that the lifter rod is engaging with the lifter arm properly?
Figured it out, the cable i got a few weeks ago is the wrong size and the new clutch doesnt slip so you notice it now. the asv levers spacer was missing as well
