XL250r stator test results .... any advice welcomed
Hi All
Re missfire ..... checked stator via tips on utube. checked ohms between all 3 wires ... yellow and red 1.2. yellow and white 0. white and red 0. Then tested 3 wires for grounding ... yellow fine, red fine, white grounding with .8 to 1.2 ohms. Going by info grounding wire is not a good stator and also my first test with ohms between and crossing over wires at plug , they all meant to be around 0.5ohms.
So all in all seems to be stator issues.
There is a 4th wire being green and red but this seems to be the neutral light by my wiring diagram and has been disconnected down by the housing
