Help! what's wrong with my 200 exc
My bike stalls after about 10 min of riding. If I put it on reserve it runs again, even though it has a full tank?
Your petcock is messed up, could be the filter is plugged that is in the tank or that the innards of the cock are jacked. Drain the tank, pull the petcock out and see what you got.
It seems like its not getting any air kind off...but switching to reserve then its fine again...I filled it up while on reserve...could that be a problem?
no that can't cause an issue. Will it run as long as you want on reserve?
Pull the gas line off at the petcock and try turning the valve on and then on reserve, see if the gas flows at the same rate.
Will try all of these as soon as I have time and before the wknd of course. ..will let you know what I've found.
