carburetor question
Hi, i have a 2005 yamaha ttr125l and i need to replace the carb and not sure wich one would be the best ? Thanks
Why you need to replace it??  If it's gummed up, you can clean it with carb cleaner or brake cleaner really well.  It'll probably work fine.  How old are ya son??
Even if you do need to replace the whole carb for some reason, your choices are going to be limited pretty much to the OEM item unless your wanting to do up some sort of a modded pit bike. But if it's a stock TTR, stay with the OEM carb.
Just ran the TTR125 with the new VM24 carb for the first time.
Runs great! Starts first kick every time with no choke..
Way better throttle response. Feels like a new bike! What a difference!
Pilot Jet:   27.5
Main Jet: 170
Air screw: 1-1/4 turns out
Needle position: 2nd position from pointy end
