amont of play in sm rotor?
how much play (if any) is there meant to be in sm rotor? mines allways had a bit but i think its got worse, ther about 2mm. i've put link to a video
Back in 92 when the kx's came out with floating rotors, so loose they actually rattled. I wouldn't go out an buy a new rotor if it works okay.
Spray some break cleaner around the rivets and try to wiggle it around. They are made to let the ring expand during braking instead of warping.. I think mine moved a little when new but not now. I wouldn't worry about it unless you can feel the movement in your lever.
I thought they were meant to have some play. I always hear it move when I move bike back and forth with brake on but yesterday I looked closely at it and it felt like a bit too much then I compared it to my mates nearly new cbr600 and his was pretty much solid so I got a bit concerned coz i don't want it comin apart when I'm braking hard at speed :o
