There are 6 differences between an E frame and an SM frame. Question for E guys...
In these images the E frame is gray and the SM frame is black.
#1: The rear tank mounts. The SM frame has an extra piece of bracket on top of the rear subframe hinge for the tank flanges.
#2: The front tank mounts. The E has a bracket on both sides, the SM only has one.
#3: The front tank bushing mounts. The E does not have the bushing mounts.
#4: The kick stand switch bracket. The E frame does not have a kick stand switch bracket.
#5: The E frame has no steering lock.
#6: The E frame has no rear brake light switch bracket.
My question for you E guys. How does the tank mount? I'm replacing the frame in my SM with this E frame. I got an IMS 4.0 tank and need to know if I have to cut off and weld any of the SM brackets over to the E frame before I send it to powder coating. If the E tanks use the forward screw mounts do you think it would be fine with only one side? I'm fairly certain I need to cut off the left side to fir the radiator fan.
Edited by raimondi1337
Assemble it and do all your fixes before you get it painted.  :banghead:
Edited by billdirt1
The E tank is only fastened with two sideways screws (onto those mounts in pic #3, of which the SM only has one). In the rear, it doesn't have any screw holes... Instead, it's held by a rubber belt thingy that goes to the rightmost bit of the frame in pic #1.
Do you men the tank? I don't even have a basin large enough to dye it in yet.
Thanks for the info guys.
No, I meant it would be a good idea to make sure everything fits on the frame before you paint it.
I just have it side by side with the old frame. Everything is the same, except these things, plus the two edits I'm about to do to my original post.
Just for clarification purposes only...Aussie model E does have #4...#5 and #6.... :shocked:  :D
Jelly. I'm cutting the brake switch bracket off the old frame and welding it to the new one because "hurr durr street legal" :p
