Oil leak from the exhaust pipe
Hello,
Newbie here. I have a KDX 220, two stroke. It rides good.
But I notice there is oil leak from the exhaust pipe extension. I am not sure what it is I took a picture below.
http://www.screencast.com/t/nnUdy4HLSsC3 oil leak is on the arm bar
http://www.screencast.com/t/OwyKG5yFxb leak is coming from here
My trainer tells me its because I am not riding at high RPM yet and not to worry. he says this happen when your putting around the track and not running with throttle wide open
Thanks for any help
Edited by goodoboy
You are bogging that thing too much two smokers will ooze goo unless you keep them rapped out.
What does bogging mean? Does it means I am just riding slowly?
clean out ur carb, replace the rubber o ring/seal where its leaking from, re pack ur silencer, and re-jet (If necessary)
and bogging means: when ur not making any power, almost as if ur engine wants to cut off (low rpms)... ride a bit harder / faster... keep the revs up so u dont foul the plug.
I rode my 125 wide open throttle 24/7 and it still leaked goo. Its a 2 stroke thing
No it's a setup thing...
All the two strokes I've owned, or ridden have dripped a lil oil goo out the exhaust. Not a lot at all, but a lil.
Replace the rubber peace that seals the connection between the pipe and stinger. These bikes like to lug, if you run an after market exhaust, an throw the air box cover away it gets even better. You don't have to scream it's guts out, mine went faster a gear high just of the pipe.
Bogging men's riding it at low rpms, two strokes like to be revved out to keep all the cobs blown out.
Yes, I ride a low rpms alot. My trainer said the same thing. Its a learning process for me.
they shouldn't really if the bike set up right. You should be burning enough oil that it doesn't get goo on your exhaust
