07 kx450f running poorly.
I recently installed a flywheel weight on my bike. Prior to this it had been laid on its side for a few days. After the installation i stood the bike up and kicked it over. Would not start with the choke on. When i managed to start it with the choke off it was running poorly and would die on its own frequently. Anyone know what the problem is?
carb may have dumped a ton of fuel in the intake or airbox maybe? Does it smoke? A little oil past the rings?
Also....that flywheel weight...since its the last thing changed....double check it...maybe take it back off as a test...to eliminate that as a possibility.
Edited by jeffdanger
Took it off and it ran fine. Put it back on and after many many kicks it would not start. Doesnt make sense to me.
