what piston ring gose first on my 2005 husky te250
hey guys I'm you to all the dirt bike sean just got my 2005 te250 but I've had such bad luck it's a long story but was wondering if anyone knows what piston ring goes first there's two that look the same but one has a little bit of like silver around it if anyone can help thanks...
The oil ring on first starting from the bottom.
2nd ring should be a solid color black or dark grey.
Top compression ring is the one with the silver around it.
This is how they usually go on.
But sometimes the ring pak can be different as to the mfg of the piston.
Always check the shape of the ring, some are tapered as in the face or edge of the ring is thicker than the inside of the ring.
If so make sure it goes into the ring groove that is cut  for this configeration.
Some times this is hard to see so if the ring doesn't seem go into the ring groove easily and won't squeeze down try another groove.
Later George
That's exactly what I was looking for thank you very much I will probably be asking more questions on this form but thanks again ..
