Not sure what the issue is
04 rm 250 jetting was good last time I rode which was a month or so ago, been working a lot. Running a rekluse also a fww. Seems like it is bogging on the bottom. Acts like it takes a second to clear up an bam there's the power. I'm thinking possibly changing the pilot jet or adjusting the needle. Taking a break figured I would post on here before I pull the carb off. The temp has changed prolly 10-15 degrees since I last rode too
Check the carb body gasket. Its inside the carb; youll see two small hex head bolts next to where the main jet screws in. Take those bolts out and pull the tower out and youll see a rubber gasket. When those crap out it gives symptoms like yours. The gasket is $8 on jetsrus.com.
Any idea what else it's called having a hard time finding it. Would it not be on the oem diagram
