Fuel tank
When you need to remove the tank on 2014 kx450 do you need to drain the fuel first?Older bikes you could shut off the fuel but with the newer there isn't a shutoff,will the fuel run freely through the pump?
No shut off needed. Just remove the quick disconnect downstream from the fuel pump on the bottom of the tank and remove the tank.
