2013 Engine knock after 12 hours
So here is the deal
Bought a brand new left over 13
Only thing done to it is a rekluse core exp 3.0 with rekluse basket
Other then that its bone stock. Even has the stock pipe on it
Took it out the other day and it seems to have a slight engine knock
Immediately pulled the oil which looked crystal clear. not a spec of anything in it
It could have some potentially crappy gas in it but its unlikely.
Bike has had an oil change every 3 hours
so now what? I just sold my 09 to buy a more "reliable" bike and now I'm starring done the barrel of $2k for an engine.
Called my dealer to ask them what to do and got told to drop it off where honda may or may not help and i may or may not get stuck with a $500 repair bill just for looking at it
What should i be doing now other then being pissed off? Anyone have any recommendations?
Im running the honda 10-40 regular oil in the bike. Air filter was replaced at like 5 hours with a twin air. nothing visible in the air box or throttle body
Also just a side note
When i put the rekluse basket in you have to take off the right case half
My worst fear initially was that when i put the case half back on i did not properly engage the water pump spline back and it may have over heated causing damage.
I then immediately checked the coolant which was nice and full with brand new honda coolant, second, i pulled the water pump cover over and moved the kick starter to make sure it was properly engaged and spinng when i pushed on the kickstarted which it was.
So everything seems fine there
Maybe drain the fuel and put some higher octane race gas in it to rule out that possibility?
yes you can. it will run richer (lack of 10% ethanol) but not by an amount that will matter for what your testing.
gotta love them 4 strokes when your looking at when it's time to go into the engine. yay for the economic stimulus!
Edited by MrMotorhed
All the vp stuff i have seen says its leaded
There were some other people in a different thread making a big deal over the fact that its leaded and saying that will cause harm to your engine???
thoughts?
thoughts?
2013 crf450r. I was assuming this is your bike. if it is not please clarify. tetraethyl lead degrades a couple of things on modern automobiles. these are, in order of serverity, catalytic converters and oxygen sensors. vehicles with a cat that are run with leaded gas tent to melt the converter shut in quick order. fortunately your crf has no catalytic converter. the oxygen sensors tend to degrade much more slowly in the presence of leaded gas. slow enough that they still have value as a sensor over the course of several tuning sessions. leaded degradation typically does not apply to modern wide band 5 volt sensors. your crf doesn't have an oxygen sensor either so good news for you there.
what else were they saying in this other thread that leaded gas screws up? i'm always amused by the prolific propagation of misinformation. bs can tend to be rampant.
No one went into detail just that it was bailed generally run shell vpower pump gas with no issue
Only difference is I put gas from a country bumpkin store in last minute when I was about to run out
And it was only 50/50 crap / vpower
Edited by automagp68
Did you pull oil filter to see if there was any metal fragments caught by filter?
Yep, that's the next step...
Ok just got back in
Im religious about my oil.
Here is what i just did in the last hour
Drained all the fuel out.
Refilled with Shell Vpower which is what i normally run with no issue at all
Dropped the oil yet again. Crystal clear not a spec in the Coffee Filter
Droped the oil filter out and cut open. No a single spec in it. Perfect flawless, just like i would accept a new motor to be
Checked the colony just for kicks
Refilled everything
started her up and same crap.
Also, new predicament i noticed. Bike is extremely hard to get into neutral. That might be a rekluse adjustment but just thought i would add that in.
Just incase anyone is wondering, no i did not hammer the center hub not on with an air gun. It was torqued precisely to rekluse specs at 50 ftlbs
just a side note
I grabbed my iPhone and shot a little video of it.
Im going to get it posted in 5 min. Stand by
Thanks in advance for the help
Sounds ok in the vid. Logic dictates that if you screwed around with the clutch side of the bike you might have done something wrong...
I agree eddie, the first thing i suspected was the clutch. I have had that clutch apart countless times and pretty good and putting it back together. The clutch behaves perfectly
The video around 12 seconds if you listen real close you can hear it knocking. The iPhone unfortunately does not do very well with this. The video sounds pretty good to me also, but sadly in real life it sounds pretty terrible. I might try again with my go pro
More like the cushions between the clutch basket and the gear attatched to the back of the clutch basket. When those get worn out one of the tell tale signs is knocking
Edited by mrmoto35
unfortunatley i wish it were that simple
You must be thinking about the core 2.0
The 3.0 does not use the cushions anymore they have done away with it.
This is coming from the top of the motor it seems its not from the left case
Also, one more note to add, 12 hours and the valves have not been checked yet. Any chance valves out of waco could cause this?
I was just about to send it to my guy for a valve check and then this started.
I don't think it will be the valves but I wonder if the decomoressor has issues? hopefully it is not something worse like rod knock. Pull the valve cover and check everything throughly and go from there
It doesnt sound terrible. Have you got the stock clutch you could put back in? Then you could eliminate the clutch/basket.
