Low end bog 07 Crf250r
I have had this bike for a couple years now and have never had a problem with bogging at low rpm. The problem only occurs when going from low rpm to WOT. Not only will it bog out but in some cases it will die completely. I've adjusted the air screw/pilot screw and it didn't help. I've also tightened the insulator boot and changed the spark plug. I've done some research and found that this is quite common on crf250's but I couldn't find any solution. if anyone has had a similar problem and found the solution let me know. thanks in advance
