nx250 help.
Hi, recently my dad got a clean nx250, has been sitting for several years in storage.
I cleaned the carb, new air filter, oil change and drained the fuel and added new "premium" unleaded, new plug and lastly a new battery.
Turns over great. It starts for about 1 second then dies, always at the first push of the button. Doesnt matter how long you hold it after that it wont try to start. It has spark.
Not sure what to look for now? I made sure I got all the vacuum lines back correctly so Im not worried about that being a problem. Doesnt start at all if the choke is on or you you give it throttle.
The NX is known for CDI troubles. See if it will run by shooting starting fluid in the air box. If it does then us sounds like a gas/carb problem. If it won't run on stating fluid I would start looking toward a CDI issue. They are fairly cheap and available on eBay.
