Starter removal
Searched, couldn't find any info. How hard is it to pull the starter? I need to replace a leaky clutch pushrod seal, don't think I'll be able to with the starter in the way. Exhaust needs to come off, then I see two bolts on the back of the starter, then pull it out from the right? Seems straightforward just want to make sure I'm not missing anything
If you still need to remove your starter I just looked in my manual and it looks pretty easy.  It did note :  The starter is sealed to the covor by an O-ring, which causes resistance during removal.
