blink codes 2011 350 sxf
So I have two blink codes going off.
First one is 6x short blinks which is tps input too high or too low.
Second one is 4x long, 1x short. Which is fuel pump control- open/short circuit to ground.
Anyone else ever have these codes?
Any info would be helpful.
Thanks
Try a new fuel pump relay , they are common for failing , not sure on the the other , but it sounds like bad earth's , maybe the sub frame to main frame is not making good contact
I had a 11 250. The tps can get bumped and than be incorrectly positioned. If you loosen the screw and adjust the tps until the blink code goes away and the bike runs smoothly it will be fixed. Remember that it is a extremely fine adjustment. As for the other blink code I don't know.
Hopefully you can get it under control.
Jared
