Shift shaft seal...
This is my second post regarding my SSS (shift shaft seal) and I correctly replaced it with a genuine OEM seal and now it is leaking more oil than before.
Today I removed my shifter and tapped it in some more and to my disbelief...STILL OIL. I'm beginning to get frustrated with it and wondering what I'm doing incorrectly now or if something else needs to be replaced.
Any thoughts and answers are always appreciated,
Bloc/CarsOnCars
Did you protect the seal from the splines of the shaft as you installed in over the shaft with plastic bag and grease?
that will aide with not damaging the seal, what technique did you use to remove the old seal?
