Cr125 bottom end question
I don't have the tools to split the case was I was wondering if some play in the rod is normal I have a video that I will try and post
A little side to side is normal but you dont want any up or down play it will just get worse in a hurry.
Could a little play in it make the piston gouge the cylinder head as crack it? I recently found a crack in the cylinder
Yeah if the bearing or bearings are very warn. You probably would have heard engine noise before that with some rattling or knocking.
