13' 350sxf stock spring rate
Hi everybody,
I just bought a 13 350sxf and the previous owner had the bike set up for a 215lbs. Vet B rider. I an 185 lbs Vet B rider. Does anyone know the stock spring rates for this bike? Also what is the stock suspension set up for general weight wise?
I am setting the sag now. Is static sag 60mm and race sag 105mm a good place to start?
Thanks!
I think they are 0.47 and 5.7 but yours sound much stiffer , static of 60 is way too much
That's right in the stock springs. I'm about 215 vet b, and I run stick springs with a revalve and 20 cc over the recommended for oil. So you may need to respring it down aways if the former owner had it stiffened up. Stock is pretty stiff
I think im going to send it out to Factory Connection. The previous owner had it revalved by some local guy. Probably be best to just have it done right from the get go.
Thanks for the help guys!
