Enzo suspention oil volume?
i picked up an 06 YZ 250F with enzo suspention and the seals are just starting to weep so in the process of changing the seals i discovered that the outer fork oil volume is 275cc in each fork.  i have no issues when riding with the forks, but that seems really low considering the manual calls for around 350cc.  does enzo normally fill their forks with that amount of oil?  the previous owner could have drained some out if that is not the normal volume enzo uses, think i should i bump it up to 300 or 350?
I doubt if the the oil level should be that low. If I was you Id just call Enzo.
i filled it to 350.  guess i'll find out and figure i can drain some out through the bleed hole if needed.
