Klx140 EO carb kit, need advise with the airbox
Hi I recently got a Carb Kit from EO but I would like to use the pod filter inside the airbox as a protection against water and mud.
Can anyone give me some advise about the air boot?
I'll appreciate some pics of your pod filter installs. Thanks
After nobody gave me a hand with this, here's what I've done:
First, fit a 1.75in ID reinforced hose of about 5in length between the carb and the airbox, let it go inside for 1/2in.
Second, insert a 45°, 1,75in OD aluminium elbow in the hose.
Third, attach the supplied K&N filter.
Fourth, clamp everything (carb, elbow and filter)
That's it! works great and no worries about mud.
Note: you have to open up the airbox to ensure enough flow for the new carb. I cut the snorkel to the minimum and did a big hole covered with stainless steel mesh the the part of the lid that is covered with the side panel.
