Stuck bolt
make sure you're threading it the right way first
get some pb blaster spray it down and let it soak over night then give it a try if it's still stuck torch it
1 pb blaster it
2 heat it 3 try and snap the head off and then punch the center of the bolt to make a pit to drill it straight... Either cut new threads in the hole or put a nut on the backside with a new bolt going the ought the hole you just drilled out
