2005 ktm 450 brakes pushing thru
So I am not sure what the problem with my brakes are. I will put my foot on the brake it will lock up for 2 seconds then the pedal will push thru. does anyone have an idea on what is going with my brakes. Thanks for any input
From you description, it sounds like rear brake master cylinder internal seals are leaking.  This is assuming there are not any other external leaks.  I don't know if they sell rebuild kits for your master cylinder.
If you just have a spongy pedal then try bleeding it to get the air out.  Your description sounds like the rear brake feels normal then sinks past the point of wheel lock up and rest against the stop.
