YZ80 Tranny Stuck in Neutral
Just completed a full rebuild of an '01 yz80. Everything's sealed up and back in the bike. Started it up, idled for a bit, tried to run it through some gears while on the stand, and nothing there. No shift action at all. The lever goes up and down, but nothing engages.
If anyone has any suggestions before I break the engine down again, let me know. Thanks.
Don't split the cases yet. You didn't say what you feel when moving the lever up and down. Drain the oil and remove the right side cover, and move the external shift lever full range, while observing the other end of it turning the end of the shift barrel and the spring loaded shift detent roller is doing it's thing.
