07 kx250f idling and bottom end power
Te packed my exhaust and now wants to stall out at idle or I turn it so it doesn't stall but then it's too high, no happy medium, tongue curve is drastically different.
This normal?
Repacked*
No, it isn't.  You need to replace the copper gasket (washer) from head to head pipe and make sure the mid-pipe joint is sealed.  The bike should run better after re-packing, not worse, but if you install the exhaust incorrectly it will run much worse.
Well it used to pop a lot before repacking on decal now it is not as bad I know where it slips on that gasket or what ever you call it is shot but it was before repacking too.
