fcr repair with jb weld?
i picked up a slant body fcr from ebay for $25. i've totally stripped it down and noticed that the carb body is worn where the slide wheels move up and down,much more worn at the bottom of the slides movement. i know this is a common problem. just wondered if anybody has come up with any solutions and will an epoxy resin fill the wear grooves. jb weld is said to be fuel resistant
alumaloy is Not all its cracked up to be! Only attempt an alumaloy repair on horizontal repairs. It will run off anything not horizontal. Also depends if the metal your working can take the heat required for alumaloy to melt, I've had the work piece turn to jelly before the rod melts. My vote would be save your money. I gave all my alumaloy away to my neighbor and now have a tig welder.
i'm at college at the moment so i have access to a tig welder,i am also a very accomplished welder as that is my job i'm just not sure i will be able to get into the small area where the slide goes. i'll try the alumaloy on some scrap aluminium first then bash it with a hammer and see how it holds up. my other option is to get a long nozzle for the tig and see if i can get in there. just seems such a waste to throw away an fcr because of a little bit of wear. i'll post some pictures of my attempts as they happen
i already have another fcr or my drz. i just purchased this one on ebay because it was so cheap. 35 dollars including postage is not bad. if it becomes a paperweight that is fine but aluminium is infinitely repairable so something should be able to be done. as a specialist welder i will set myself a personal challenge to fix it.
  • Like 2
  • 1 month later...
just an update on repairing the FCR. i took it to college today to have a go at repairing it. the carb body is not cast aluminium it is die cast so that rules out any sort of welding due to the high zinc content. i had a go at braze welding it and it started blistering before i even got a chance to melt the filler rod,again due to the high zinc content. so all in all i am still stuck with a paperweight
  • Like 2
next thing i will try is i will take a hacksaw and cut a larger channel where the grooves already are,then fill it up with jb weld and  make it smooth,once that is done i will soak it in fuel for a couple of weeks and see how it holds up. lot of work i know but just have the urge to find a solution
Yes well you have nothing to lose....except your time.... :excuseme:
