Ktm 250 sxf 2007
Hi guys i am new to thumpertalk and I just bought a 2007 ktm 250sxf (the one with the new style plastics ,it has a problem of when it accelerates it goes for a few meters and then sounds like it is gonna cut out but then suddenly takes off , i have no idea whats wrong but the guy i got the bike from said something about the jets or timing ... I dont know . Anyone have any suggestions on what the problem is
good to know krannie, I was remembering a bike that had a flat spot after accelerating hard but if you where gentle on the throtle it just went fine no hick up and that bike did have  a blocked squirter jet- but I'm still learning.
If your problem only occurs with very quick throttle (at rpms that are not too low) then it is your accerator pump, and it probably is clogged
If it happens other times, it can be either a rich ( blubbering sound) or lean (like a kill button) or a bad electrical connection (usually random, or after the motor gets hot)
