Does my inner clutch hub need replacing?
I was having a couple clutch problems so I decided to take it apart
Outer hub looks fine, but what about the inner hub? I don't think it needs replacing.
Also, on the pressure plate (that goes on top of the whole clutch) there is a crack, does that need replacing as well?
Happy riding
So i was tearing the bikes clutch assembly apart and noticed that there was slight grooving in the inner clutch hub.  It looks much worse in the pictures.  Do i need to replace it? I dont think its that bad but this is the first time I'm doing it.
Also, the pressure plate on top kinda has a bit of cracking on certain spots
Should I be concerned by this?  Does it needs replacing? Thanks for anyone who helps
Better to replace the PP than have it grenade in the engine. If you can catch your finger nail on the hub indentations that should be replaced as well.
The pressure plate is done. There is so much hear build up that I wouldn't risk it. If you feel the grooves on the inner hub it is done as well. They just don't last all that long
Happy riding
I wouldnt change the inner unless you can feel them. Even then you can file them smooth one time before needing a new one. That pressure plate on the othere hand would make me nervous...Almost looks like a repair of some kind.
The clutch hub has a lot of life left in it. Can't see the cracks in the pressure plate, but if it's cracked get a new one. They're pretty cheap cost wise.
Yeah that's exactly what I was thinking
Like someone sanded it down a bit. There's another spot like that as well
Thank you everybody who replied!
Thanks everybody who replied!
I think i have a pressure plate from a 2013 that was changed out with less then 10  hours if your intrested. Not sure what a new one cost. I bought a box of parts from a friend who swithched to 2-stroke yamahas and it was in there along with a inner hub. I think he put a billet one in
I'd love one! If you don't mind I happily take it off your hands
Just +1 on the hub and basket, they look great.  Not at all sure what happened to that pressure plate, but sounds like you found a solution!
Let me see if i can find it and make sure it looks good. I have not looked at it since i bought it. Also are you in a hurry????Cause im leaving for Mammoth National on wensday for 10 days.  Pm your address so i can figure out what shipping cost.
