before......
wheel off.......now we are cooking
cant forget the parts....
outer bushing.....gennie from yammi
dust seal and main seal......yammi parts again
inner bushings...racetech........cheap on ebay :)
all apart........used homemade tool of all thread with a metric nut welded on the all thread............and a broom handle jammed in the dampning rod ( no pics of either )
i swear the nasty black oil that i drained out of these forks was from 1986 !
as per RT instructions......holes drilled out to 5/16 and more holes added to dampning rod
inside of lower fork leg.....where outer bushing and seals go........for those of you who have never seen
reassembly......inner fork bushing installed on upper fork leg (  not shown ) ......dampning rod with top out spring goes into upper fork leg.....then inserted into lower fork leg and bottom allen bolt tightened
Edited by sjsingle1
allen bolt that goes in bottom of lower fork leg.......no it does not use 2 copper gaskets
washer over outer bushing installed and driven home with fork seal driver
main seal install.......grease it up........and use plastic bag to prevent seal tear while installing......do the same for dust seal install ( not shown )
gold valve
01ae6844-8bf1-4f5d-9c30-003a53bd9cae_zps
install gold valve on top of dampning rod..........add oil......set my oil level 6 inches from top
install spring on top of gold valve........the GV instructions specifies 10mm of spring preload.....used 1 inch sch 40 pipe rather than cut stock metal spacer
put fork caps on ...........and then install forks back in triple clamps
all done ! forks are much plusher now and very resistant to bottoming out
:thumbsup: Thanks. I still prefer those type forks. Very easy to get them excellent as compared to modern stuff where it is very easy to screw them up.
the original yellow fork boots were very nasty.............got the black ones and was happy......when i did this rebuild i found out that the boots were trapping water on top on the dust seal causing the seal circlip to rust.......gotta find some better boots
Those '86 's are hard to come by, where are you going to ride that thing? Would like to take a look at it.
