08 530 Clutch problem
Hello,
So the last few days the bike started acting weird, when I would pull in the clutch while in gear and coast, I could hear like a screaming noise almost, and the lower the gear the louder it was. No noise when in neutral and coasting though. Clutch seems to be pulling in fine, and I decided to open it up to inspect the clutches.
Everything seemed fine and normal so I took the whole side case off.
I havent done much to it since purchasing it last year so I didnt know exactly what to look for.
I found a bearing that has quite a bit of play, and when I rotate it by hand it seems similar to when I hear it driving.
Here is a picture and video of said bearing.
ANY help would be appreciated.
