Suzuki DRZ400E Camshaft Cams Set A / B DRZ 400 E 2003 low miles
That is EXPENSIVE for 10+ year old USED cams IMHO.
X2. Especially when you can have a brand new set of HotCams at your door for $20 more than that old used set? Not worth it at all.
  • Like 3
Not looking to buy,  just seeking knowlege. So what Hot Cam do you reccomend that would be most like the 9.29mm lift and 272deg duration that the E exhaust has?
Yes the E does have the auto decomp on just the exhaust cam.
Interesting. So just the K has he manual decompression lever?
So with that E exhast cam, I would be covered for cranking with my S?
I would take into account the Decomp on the E cam is 10 years old too
Interesting thought. Were there problems in 2003 with the decompressors?
The E exhaust cam has 243 degree actual duration.....
Hotcams stage two inlet matched with the E ex cam is a good pairing....E cams
Edited by Craigo 485sm
I'm under the impression that 243 is at 1mm, not total actual, based on these two references;
These specs are directly from Suzuki PR:
Suzuki DR-Z400E
Valve Lift Intake: 8.9mm
Valve Lift Exhaust: 9.3mm
Intake Open: 14 BTDC
Intake Close: 66 ABDC
Exhaust Open: 65 BBDC
Exhaust Close: 29 ATDC
Suzuki DR-Z400S
Valve Lift Intake: 8.5mm
Valve Lift Exhaust: 8.2mm
Intake Open: 20 BTDC
Intake Close: 55 ABDC
Exhaust Open: 56 BBDC
Exhaust Close: 19 ATDC
Hope that helps.
Webmaster
4Strokes.com
http://www.4strokes.com/forums/topic.asp?TOPIC_ID=12269DRZ-cams.gif
