02 CR250 fork problems
I am trying to rebuild the forks on the 02 Cr250.  I can not get one of the inner tubes to function correctly.  The first one i did came out okay, but the second one slows down 3/4 of the way up and needs help to fully extend. I tried starting over 3 times and tried to bleed them but still cant get them to work right.  Any ideas what could cause this?
One of your o-rings, either the one at the tip of the cartridge or the one seated inside the compression base, is leaking.
Cool, thanks.  I had one of the o rings switched with the rebound adjuster one.  Switched them and everything is working good now.
