2013 kx450f white smoke and milky oil
When I am out riding my 450 and I rev it or do a burnout(in grass to turn around at gates) I get a white puff of smoke and the oil looks milky through the watch glass. Does this mean that the engine is blowing or the water pump seal has broken? Please help
The previous week I hit a kangaroo on the water pump side and maybe that that had something to do with it
If the water pump cover looks ok, then I'd guess the roo didn't break anything there. Probably worth removing the pump cover to inspect but that'll mean a new cover gasket is needed.
Check your spark plug for any signs or smell of coolant. Also see if you are losing coolant. You might have a leaking head gasket. Which could be just the gasket or it could be head warp too. Easy to fix.
Does the white smoke smell like engine oil or boiled coolant?
Edited by numroe
You hit a kangroo?  One aspect of a riding story I will never have.  Jacked up a rattle snake the other day and got stung by a bee.  Pretty extreme up here........not really.  I woud start with the water pump seal and flush you oil and go from there.
Yeah, that kit looks good.  Check your spark plug. A quick look and sniff should do.
As i recall there are double seals and a weep hole in between them so the idea is that you shouldn't get any in the oil if you have a coolant leak. having said that ther is the gasket between the side cover that could be leaking or the head gasket or the base gasket. I had an athena cylinder that seperated and leaked into the oil, my best guess would be head gasket if your getting white smoke.
you'll need to replace it once you break torque on the head.
Preferences
1
2
3
4
5
6
7
8
9
0
Backspace
Tab
q
w
e
r
t
y
u
i
o
p
Return
capslock
a
s
d
f
g
h
j
k
l
shift
z
c
v
b
n
m
shift
English
Deutsch
Español
Français
Italiano
Português
Русский
alt
alt
Preferences
Edited by RyanH216
