Crankshaft play
I pulled my piston out yesterday to measure it for tollernace and noticed that my Rod has left to right play in it...a fair amount.  Is that normal?  The motor is still on the bike so I havent split the cases, and didnt plan on it, but may need to now if what I am seeing isn't normal.
Edited by WarHammer0106
They normally have some play in them...spec calls for .012" to .030".
It's hard to gauge big end rod wear...the thrust washers only wear below the outside circumference, so they may measure correct when in fact they are in the process of failing.
The only way to know for sure is to replace it...
I havent seen any gold/bronze glitter in my oil when I change it.  I got the bike in Feb 2014 and have changed the oil 3 times.  I hate to put any pressure on you Paul, but if it was you would you split the case and be sure, or if I havent been seeing any thrust washer shavings in the oil then I am probably ok?  The bike has had an engine noise since I bought it and it sound like its in the top end.  The piston that I just pulled out of it was out of spec by a good bit.  I was hoping that was the sound that I was hearing.
No gold is a good sign, but that doesn't guarantee anything.
If the piston was under spec, piston slap was likely the culprit.
If this is a bike that will be raced or used on long haul, Baja style trips, I'd replace just for piece of mind.
If it's not likely that it will ruin a race season or leave you stranded 100 miles from civilization, you may be able to take a chance.
Only you know if saving the $ 300 for a new one is worth the chance.
Thanks Paul!  I am not doing any big Baja style rides on this bike.  I will consult my repair manual and find out if I am in spec or not.  If I am not in spec is there a reason that I should use or not use an OEM crank and rod?  I do appreciate the knowledge that you and the rest of the forum share.
A reason for works
You can NEVER go wrong with OEM...on almost everything except that damn front tire. :)
In this case you can also use the Heavy Duty Crankshaft from Hot is as good as OEM (if not better...)
ALWAYS stay away from Wiseco cranks, even if they are FREE!!
Just measured the's well within spec. I got a .012" in pretty easy but a .017" is where I got a little drag from my efforts. Not sure why I thought it was a bit loose but it's surely not. I will leave the motor in the frame and not split the case.
I  thought Crankshaft play was a sexual term.
We know you love you X Kah Ran Nee but that is taking it too far.........................
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
