After I installed a bearing I noitced this! 2013
As you know I have been doing a new engine build with a brand new crank case.
Ok so I noticed a small line near the one bearing I was installing this is the stator side shift drum bearing.
I also took a pic when I first got the case in, It looks like there might have been a small casting line there and with the heat and oil after installing that bearing I really noticed it.
Now I looked at the old case and there is a line.
Now I did have to slightly tap this  bearing in after heating the case a freezing the bearing a few times to get this in.
Now it does look like in the new pic there is a faint line.
Should I take this to a machine shop and have them just weld a line just in case to reinforce this area. There isn’t anything on the outside of the case, no stress cracks or anything.
