Tips for transporting your dirtbikes
Howdy,
I wanted to share a tip: If you are transporting two bikes, use an extra strap to tie the two bikes together at the bars / grips. If you have full wrap hand guards (aka: Bark-Busters), that makes it very easy. If you don't, then just wrap the strap several times around one grip then over to the next, then back. Doing this will keep the bikes from leaning to the outside when turning.... which will happen no matter which "motorcycle bed bar" you use. See the pics below.... yellow strap on the bars.
Another tip: I always run a strap over the back tire(s) using the rear D-rings (near the tail gate). Very simple for one bike; If you have two bikes in the bed, put a cooler between the rear wheels to keep them from sliding inward, towards eachother.
Both of these tips help keep the bike(s) firmly in place while you travel to your destination.
I hope this helps.....
Jesse
2012 Toyota Tacoma with two bikes loaded properly.... No lean at all through turns.
just FYI you want to hook your straps into the anchor point with the opening facing up, this prevents the strap from flying up, instead if it breaks it will just fall down
Just point the two front tires at each other. Two straps for each bike and they won't move.
I never did that tie the grips together, and im sure i have no lean ever. Driven hundreds of miles each way even with three bikes in an s10
