xr650l intermittent no start. GRRRRRR
So the ol xr650l start sometimes and sometimes it doesn't. One it starts it will run just fine until I shut it off. Then, who knows. Its a no spark when it does do it. Any ideas??
start stop switch was my issue
Try smacking the back of the CDI when it won`t start,if it starts up after smacking it read my CDI repair thread at the top of this forum...
The stop/run switch can be an issue too,,clean it with electrical contact cleaner and regrease with dielectric grease......
The most common issue with no start/no spark is the CDI,,followed by the Pulse Generator and finally the stop/kill switch..
these are the most common......there are other things that can cause it of course,,but 95% are caused by these..
If smacking the CDI doesn`t work.ohm the Pulse Gen........
Where is the cdi on this bike?
It's in the battery box beside the battery. I had a CDI go not too long ago and your problem sounds the same. Mine would start in warm weather, and not in cold. I imagine this is because the solder joints would expand and make a connection where they were cracked when it was warm out.
03 XR 650L with desmog, opened air box, UNI foam air filter, Dave's mods, 55/160 jetting and Clarke fuel tank
  • Similar Content
    • By Charles Mrizek
      This replaces part 9 in the exploded parts diagram for the 85 86 87 xr600r.
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
