Smoking after oil change
So I just changed the oil in my 520sx that I just got. Using a thicker oil because that's what the bike has had through it from previous owner, now the bike is smoking and I'm not sure why?
Overfilled ?
does it smoke heavily through the exhaust pipe or breather hose?
Does it stop after running a while or is it continuous.
If the smoking stops after startup and runnin for a while its your valve seals, if its smoking all the time and you have oil comin out of the breather hose then you have a bad piston ring.
After an oil change, the bike will smoke some but should clear up soon.  As to oil, you can't beat the Castrol Edge 5-50.  You can get this on sale for around $6.
