Perelli Diablo Rosso II
I am thinking of putting these on my Drz400sm. I found a pair for a good price at the OE size. 120/70/17 H rated and 140/70/17 H rated.
I can order the following at additional time and cost: 120/70/17 W rated and 150/60/17 W rated.
Is it worth paying the extra for the W rated tires. I will never exceed the H speed limit. Will the W speed tires handle better. I am leaning toward the H tires as they are cheaper and OE size. However I am willing to go the extra for the W tires if they will make a bigger difference.
I just ran the stock size rear rosso 11. Liked the tire got about 2700 miles before I had to replace it.
Thanks. I got a great price on tires and install so I will go that way.
 I have them on my bike - stock size. I've never tried the 150 rear so I can't offer a comparison although I can say the stock size ones are great. H rated is fine as well.
i have the Diablo Rosso IIs on my bike as well.  They are the H rated.
I'm going to assume the W rated ones are for bikes that go ALOT faster than ours.   :smirk:
You are perfectly fine with the H rated tires.  I am really happy with these tires.  They grip very very well.
Stick to the 140 in the rear to avoid any complications.  I had a 150 on the back prior to this 140, and the 140 is more responsive going from side to side.
Edited by jreed1337
unless your pulling massive lean angles the 150 is not needed,its all i've ever used but i would really like to try the 140
Thanks
I ended up with the 120 front and 150 rear. This what they had in stock. The grip is really nice. They turn in a little slower then the dunlops but the traction is great. Very confidence inspiring.
