CLARIFYING...atf type f
Yes i know, i know....
Was at the ole tractor store and decided i'd get some atf for my yz, but only saw a generic 'ford type f' but said it was for 70's blah blah... Is that it? It was the only atf type f there. Walmart had a different one that didnt say for 1970's model cars, but did say for fords. JUST CLARIFYING! Dont crucify me ;)
Same stuff.
Yep, same stuff. I've used with good results.
Cool thanks. I figured since thats all i found but wanted to be sure
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
