Rekluse EXP
Really interested in putting a rekluse in my 08 450 XCR-W. The standard EXP clutch can be found for $499 while the whole CORE kit goes for $899. Wondering what difference the inner clutch basket and pressure plate and new steel drive plates really make. I know the new clutch cover is only neccessary because of its' increased depth. Most likley due to thicker steel drive plates.
I only ride as a hobby and not for a living so I don't see the need to break the bank.
Anyone have a rekluse they are happy or not so happy with? Thanks!
I love the EXP 2.0 in my 500. The 3.0 is supposed to be better as well. I've read that the 450's do fine with the EXP but the 500 are bet better off with the Core.
Thanks for the insight. I am leaning towards just the standard clutch kit due to cash constraints but I need it to do what I want.
they take a little getting used to. Like climbing a hill and the motor starts to slow down, you want to reach for the clutch to start slipping it, but the Rekluse will take over and do it for you, but it takes a few rides to overcome your habits of clutching.
I wish there were more hills, but in Northeast Florida the landscape is very flat. Just took up trail riding after over 20 years on sport bikes. I think dodging trees in tight quarters will be much easier with the rekluse. My clutch hand was worn out last Sunday. Am I on the right track looking for it to help me with tight trails? I did read that you can run a gear high with no issues. My 450 can barely get out of 1st on the tree lined trails I ride, and we all know how twitchy 1st gear is. Thanks for the insight.
Edited by Warrant
you can run a gear high, but to do this the Rekluse slips...slip means heat in the clutch which will lead to many other issues if the slip is too much...I used mine to ride a gear high often so Im not saying dont do it, just be aware of the possibility of excess heat.
The only real problem I had was hitting the rear brake to do a corner-a brake slide- if the timing wasnt right in getting off the gas before hitting the rear brake I would sometimes stall the motor and no bump start with the Rekluse.
A Rekluse will be just what your looking for. It will make tight single track much easier, faster and more fun!!
The difference is the Core comes with a new inner hub which is taller and allows for all frictions to be reused rather than removing some to make space for the EXP disk like with the EXP kit. Their steel plates are redesigned for better cooling and oil flow. The steel plates arent thicker, the added depth is to make space for the EXP disk without removing frictions, only 1 friction is removed but the EXP disk takes place of it, so acutally the CORE EXP is same as stock with reference to amount of frictions and steel disks.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
