Taking apart top end after a poorly done rebuild. Argh!
I blew out the base gasket on my '95 XR650L a few days ago and finally got the time to take apart the top-end...
Problem confirmed!
I'm at least the third owner of this bike and the guy who I bought it from mentioned that had been rebuilt.  The rebuild job was amateur and done in a rush...
So far I found one sheared valve cover bolt:
And a missing dowel pin down where the cylinder and crankcase meet.
What I need to know is...it is possible (but unlikely) that the dowel pin was in place when I removed the cylinder and it is possible that the dowel dropped into either the cam chain hole or the crankshaft hole while I was removing the cylinder.  That said...just how much room is there in the works if this indeed happened?  I fished around with a magnet and didn't find anything and I also spun the crankshaft around a bunch of times and everything feels smooth.  If something the size of a dowel pin had dropped into either hole wouldn't it be big enough to catch on something?
The last thing I want to do is put it back together and have it self destruct due to an errant dowel pin.  I was hoping this would be a relatively quick repair.  I really don't want to split the case...
I think the best option may be to tip the engine upside down and give it a few firm shakes...tough to do at the moment given what's left of the engine is still in the frame.
The cylinder, head, valve cover, camshaft, and piston all went to my local engine shop, I'll get them back in a few days.  He determined that the base gasket failed because whoever installed the cylinder did NOT follow the correct torqueing sequence and/or overtorqued the bolts, thus the base warped.  It will have to be machined to get it back to spec. Same story on the head, it's warped too but not as badly.
Sigh...if you are going to the trouble of doing an engine rebuild at least do it properly!  Argh!
  • Similar Content
    • By TheLastByte
      Changing out my fork oil on a new to me 650l. What's generally recommended for stock springs and valving?
    • By mrdsee
      ~177 Titanium bolts, nuts, washers etc leftover from various motorcycle projects. XR650, YZ 125, YZ250 a mix of new and used once hardware.
      Made by Mettec
      Over $2k worth of hardware
    • By Xr600guy
      So I don't seem to find my specific issue so here I am asking.
      I have a 1997 Xr600r. It was recently re-jetted and has ran really well ever since until more recently it has begun to have this issue.
      Everything works fine. Kicks right away, nice and easy. Runs great, sounds great, purs. But when I'm downshifting and slowing down to a stop, if I let my hand off the throttle that's when it just dies. I found that I can counter this by lightly holding the throttle as I down shift (so I'm revving quite a bit during downshift).  But it hadn't done this before.
      The only thing I've done that I suspect may have been an issue on my part was when I pulled out the engine to change the valve cover gasket and upon doing so perhaps when connecting the carb back to it, I may have missed something or made a crack in the boot?
      Any ideas? Thanks
    • By Kenya
      Hello all,
      There's been a lot of talk about how to register a dirt bike in states that don't allow it.
      I just moved to North Carolina and for the first time in my life might be able to afford a bike. I've been dreaming about an XR650R for a long time, but they're not cheap. Plated bikes seem to be more expensive too. So here's my question, has anyone tried to plate a dirt bike by adding all the necessary features and having it inspected as a custom bike? Anyone know of another way I can plate an xr650 in NC?
    • By Jsmoot
      Hoping for some help before I throw in the towel and end it all!
      Engine starts fine, runs and idles well for +/- 10 minutes, but cuts out while riding once the engine warms up (175 - 185) and intermittently cuts out thereafter (any speed/gear). It will start up after 30 seconds or so (but won't run for long before dying again). No spurting or surging.. just dies.
      I've replaced CDI (twice), Spark plug, spark wire and coil, and most recently pulse generator. I do have a 41mm Flat side carb from a CRF (and it has more power than the old carb setup), breathing through a Uni filter. Also, sealed battery tender battery (hasn't shown low when trickle charged).
      What's next on the test/replace list? Stator maybe? Please help...
