2006 Rebuild
Well I traded at pretty mint trx450r to get a CRF250R.. Seemed like a good deal at the time, the 250 fired right up and I took it around my block.
Changed all the fluids and went for a quick maiden voyage and the rear tire locked up as I was idling around (new to 2 wheels). So I put it in Neutral and walked it back (I was only playing around on a 200yard strip)
So far I've picked up;
Stock piston
Stock rings
Stock wrist pin/circlips
base gasket
head gasket
52T rear sprocket
Primary Drive chain
Ferrea SS intake/exhaust valve & spring kit
I didn't find any shavings in my filter, do you guys think I'll need a new cylinder? I know there's only one way to tell, but I'd like to have anything in hand before I start and not have to wait for anything..
So far I have it figured I need a;
Timing chain
shim kit
exhaust crush gasket
Here is what I'm looking at;
I own a small Powder Coating business that I'm just starting so a lot of this bike will be done for my portfolio.
Dormant Red water pump cover
some trim on the engine (still have to finish the clutch cover, valve cover, kick start and brake lever)
bit more.. coating the exhaust shield when picture was taken..
Have you looked inside the beast at all? Before I would assume it's a complete top end rebuild I would take the valve cover off and see if the cam chain skipped or broke or piled up, it is possible for a cam chain tensioner to fail. This just happened to my bosses EXC530. Engine started making a funny noise, then locked up while out on a ride, towed it back in neutral. He originally thought it was a big end bearing that was shot, but when he pulled the cover off he noticed a problem with the cam chain and that the tensioner failed. Threw in a dirt trix mechanical over hydraulic tensioner, put the chain back where it was supposed to be, and it's been running fine ever since.
It was puffing blue smoke a bit before I went for a little tour (around a 200 yard strip) and I had ordered the piston even before the rear tire locked. I was able to kick it over right away to make sure the engine wasn;t siezed tight.
When I traded for it it started first kick and ran like a champ.. I didn't notice any smoke but we were outside. Engine oil also smelled like gas.. I'm hoping it'll last a long time with the build route I'm taking.
other side done..
Have it broken down to the frame to replace the steering bearings. Thinking about putting some powder on the stock duals when I repack them too, also the tripple clamps will be shot either black or red too.
I've raced quads for a few years but it's getting hard to find places to ride/race around here so I'll be racing this bike in the C class as early as this fall.
Looks good man!
Love the powder on the covers. What kind of price would i be looking at for you to do that again?
Thanks guys! really makes the whole bike pop witht the small accents for sure. :ride:
Would be $80-100 for the clutch. valve and stator covers, if you clean them and prep them well you can pretty well cut the price in half.
Ok cool, ill definitely keep that in mind. Looks like you should put some new tires on the parts list  :thumbsup:
They are on there! Thinking about going foe the Sedona mid soft tires.. found some on ebay for 59.99 shipped and there seem to be some decent reviews on them. Anybody have any negatives to say about them?
Got the engine out and it's at my mechanic/buddy's place. I forgot to order a timing chain would have been done last weekend :facepalm:
Not much to post on, I'll update the thread once theres some more progress.
Not too long ago I put on a Sedona rear tire on for a friend. When he came to pick it up I told him I never wanted to see another Sedona tire... ever!  The sidewalls are so stiff it took 6 tire irons, 2 sets of wood clamps (to hold the tire in the center of the rim), quite a few cuss words and over a 1/2 hour to change it.  I've been changing tires for over 20 years and can usually change a Dunlop in about 5 min, to me the savings don't justify the aggravation.
Hey Thanks Slo, I think I'll just get a good named brand like Dunlop and be safe. Though I am such a noob on a two wheeler I'd hardly notice a difference I think.
I got my engine back, man these are a PAIN IN THE ASS to get the engine in and out.. I had to take the swinger, subframe, shock, valve cover and water pump cover to get it back in!
Got almost everything powdercoated that I want to do.. Finished up the triple clamps black and changed the steering bearings.. the lowerds were SHOT!
Hoping to finish up and ride this weekend :ride:
Edited by chronicsmoke
You don't have to remove the valve cover and/or water pump housing to get the motor into the frame, you just need to take a different approach than you did, and the motor goes right in.
Haha I knew there had to be a better way.. 4 pints in and it was either take them off or start hitting it lol.
What side did you put it in from?
All done and she rips again..
Good job. I like the before and after shots. The engine and exhaust look way better than they did, that's for sure :-)
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
